Thread Tools
Old 08-06-2014   #1
is annoying.
BlueDan's Avatar
BlueDan has donated!
Air con pressure sensor
Does anyone know where it is, on a 100HP in particular, so I can try to test it?
Fuse 19 and relay 05 are OK and it was only recharged around this time last year. Hopefully it's this sensor at fault fooling it in to not starting (no click or change in engine idle noise) and there isn't that bad a leak somewhere instead. :/
I've followed the pipes out of the bulkhead, one through the compressor, then both under the header tank, behind the headlight and down to the condenser and I can't see it.
29-01-2005 - 21-07-2012 1998 Imola Blue Cinquecento Sporting
09-06-2012 2008 Crossover Black Panda 100HP
BlueDan is offline Reply With Quote Quote
Old 08-06-2014   #2
Speed Reader of the Year!
Most Easterly Pandas's Avatar
Trader Rating: 2
Most Easterly Pandas has donated!
Re: Air con pressure sensor
IIRC drivers side (RHD) just where it enters the condensor (lower pipe). Near the oil filter / water pump
Most Easterly Panda's - Panda'ing in East Anglia
Stockest of mk2 Panda Parts, PM for any parts requests
1993 Classic Panda Selecta, 1989 Panda 750L,
2015 Kia Soul EV, 2009 Panda Eleganza & 2005 Panda Climbing 4x4 (LPG)
Most Easterly Pandas is offline Reply With Quote Quote
Old 08-06-2014   #3
is annoying.
BlueDan's Avatar
Ahh yes, there it is (thanks!) - simply (by small FIAT standards) remove the front fog light to view it. Access to the rear to probe at it with a multimeter, without removing it and letting any pressure (which may or may not be there) out of the system will require the use of the pit in my cousin's garage.
Likes Most Easterly Pandas liked this post
Old 08-06-2014   #4
Unplug it and short the connector, if the system springs into life either sensor is dead or no pressure in the system, although the chances are you have a leak somewhere
Maker and voice behind the YouTube channel PuntoHowTo 10k subscribers canít be wrong
And now the owner of a shiny new PuntoHowTo Drivetribe
AndyRKett is offline Reply With Quote Quote
Old 08-06-2014   #5
is annoying.
BlueDan's Avatar
Yeah, I was considering doing that instead as a brief test - easier than trying to probe at it, given where it is. I'm not sure what value resistor I'd need though, if any ("signal needs to be between 1v- 4.5v before it will say OK and allow compressor to start")? - I've got some 330 ohm already here.
Old 08-06-2014   #6
Moderator
Quote Originally Posted by AndyRKett View Post
I'd say the odds favour losing the refrigerant over a failed pressure sensor.
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 08-06-2014   #7
is annoying.
BlueDan's Avatar
Yep, tried bridging with a 330ohm resistor and a piece of wire (one then the other), no difference after running for ~10 minutes... arse!
I'll find a specialist that'll do a dye test plus required repairs once work allows.
Thread Tools
(T) Air con leak near pressure switch. mon67 Stilo 2 17-07-2013 10:56
(G) Air Con Pressure reads high Clivvy Stilo 9 03-08-2012 22:45
(T) Air inlet temp sensor/boost pressure sensor robjames3 Bravo 0 25-01-2012 16:53
(T) Air Con pressure switch 8585 Punto (Mk2/2b) 10 18-08-2010 22:29
(T) Air Con Compressor Pressure tazztham Marea 2 20-08-2006 17:57
