- Feb 9, 2014
- 9
- 5
If your Multijet Panda starts OK but goes into limp mode a few hundred yards down the road, recovers after a few minutes, and occasionally throws ECU fault lights, take a good look at your air filter. Here's why...
We have recently acquired a 2005 Panda with the 1.3 multi jet diesel. Lovely little car, most of the time except...
About one time in three, on a cold, damp morning, the car would start up fine, rev happily in the drive, and then about 30s to a minute into the journey suddenly lose all power. I'd then sit at the roadside out of the way, revving it or keeping my foot on the floor. To begin with, I couldn't more than 1000rpm, but over the next five minutes or so, the revs build unevenly towards 3000. At some point, after anything between a few and over five minutes, the engine "clears" with a puff of blue smoke, the revs spin up skywards, and the engine runs normally after that. Several times over the last month or so, the ECU light has come on after one of these episodes. Sometimes it clears after turning the ignition off. sometimes it doesn't. Diagnostics show different faults.
We've had a new EGR unit, new MAF sensor and new turbo boost sensor in response to the fault codes. And it was still doing the same thing.
Anyway, having seen pages of threads about similar behaviour, I phoned a nearby FIAT main dealer (in Cleckheaton) to ask if they'd had any kind of service bulletin, about this behaviour. The service manager said no, but he'd talk to his technicians and ask. Within ten minutes, he'd called me back, and told me that one of his team had had exactly the same fault in his sister's car, and couldn't get it running. After bringing it back from Birmingham to Cleckheaton, this guy had changed the air filter and MAF unit. Since we had had a new MAF fitted, I decided to look at the air filter.
EUREKA!
For about two thirds of its length, the air filter was absolutely sodden. It dripped as I lifted it out, and I could squeeze water out like wringing a sponge.
I can only think that once the engine start sucking air as it started pulling under load, that water was being pulled into the MAF and other sensors, triggering weird sensor readings, limp mode and occasional ECU faults. After a while, all the water that could be pulled from the filter had been, the sensor readings returned to normal, and the engine would rev freely again.
So, water going into the engine with the air can't be good. How does it get there?
If you look at the centre of the "gutter" below the windscreen, you can see that the rubber seal goes about half way across from the left. About where it ends is one screw, which goes through the firewall at the back of the engine compartment. It's the only thing that does go through the firewall -- the other nearby fixings terminate on the back of it. On the engine bay side is a plastic block which it screws into. I guess it's meant to be watertight. But mine wasn't.
Any water coming off the windscreen and gathering around this screw goes through into the engine bay and drips very precisely onto the joint of the air filter box. The air filter has a spongy rubber seal which sits in a gutter around the filter box on the bottom part, and the lid comes down on top of it to trap the sponge and make a seal. This spongy seal "wicks" all the water that falls onto the gutter into the filter, where slowly it soaks all of the paper "leaves" of the filter. The drain holes in the bottom of the air filter box are useless, because the water is absorbed by the filter before it ever get to run out of the bottom.
So what have I done?
1) Changed the soaking air filter for a clean, dry one.
2) Applied silicone sealant all around the screw, on both side of the firewall.
3) Cut a section of heavy aluminium disposable roasting tin to make a -\ section from the base and one side, and taped the base to the top of the air filter box so that the angled side sits over then rear join with its tabs and sockets, under the dripping screw, so any water that still comes through can't reach the joint, and drips down behind the filter box.
If this doesn't work, I'll be cross! It can't be right to have a dripping air filter, and the engine is clearly misbehaving while the filter is wet, so logic suggests the filter must be at least contributing to the problem...
Good luck!
bestest,
M.
EUREKA!
Good luck!
bestest,
M.
