Old 10-10-2013   #1
Denmark
Exclamation Problem with ABS and electrical system
Hi there,
I have a Panda 1,2 Dynamic from 2009 - bought used this summer.
I have had a few incidents I hope you can help with before I take it to the shop.
1. I was in a line of cars, holding still and getting ready to turn right when I had to turn suddenly I could not move the stearing wheel and the light in the ABS was on. It was stuck. So I turned off the engine and when I turned on again the problem was gone.
2. A week later I was again in a line getting ready to turn when suddenly I could not press down the break pedal. I turned the engine off and when it came back on, everything worked again.
3. Now I have just lost the backlight in the dashboard in the area where you turn the heat and air on and off.
Any ideas as to what might be the issue?
Thank you guys
RikkesPanda is offline Reply With Quote Quote
Old 11-10-2013   #2
varesecrazy has donated!
Re: Problem with ABS and electrical system
1st 2 sound like poor electrical supply,
check charging system and battery,
here's a link;
https://www.fiatforum.com/punto-ii/3...tart-help.html
#3 maybe just one of those things...!!,
otherwise look for a loose earth wire on car body,
or maybe JUST a blown bulb,
Charlie
(T) ABS and EBD system error?? private Multipla 20 11-12-2012 00:49
(T) ABS System fault freddie123 Multipla 4 05-02-2009 12:53
(T) ABS/ASR Failure - Brake system Meerkit Stilo 5 22-01-2009 14:13
ABS wiring help, electrical experts? bulldog5046 Lets Talk FIAT 3 13-10-2008 16:47
(T) electrical system fault abyss113 Bravo / Brava 1 18-12-2006 10:34
