Technical  ABS 4 x 4 169 2007 Problem
LauraD
North East
Hi All, not sure if anyone can help? I have an ABS light on. Initially when starting the car the light is off, initial driving at slow speed the light stays off but you can hear and feel the brakes pulsing when you press the pedal. Once you pick up speed the light comes on and the brakes feel and sound OK but I'm guessing the ABS has switched it's self off. I have an AUTEL ML629 code reader but this doesn't list Panda's and doesn't seem to connect (talk) to the vehicle. Any information would be very much appreciated. LauraD
You need to connect to the ABS module and read the code, without it we are in the dark
It's likely to be a sensor or wheel bearing 4x sensors 5x bearings
Or could be something else
without reading the code it's could turn costly trying this that and the other, there's 4 corners, you could guess right first time or 8th time
Let me look into the reader you have back shortly
The ABS on the 4x4 are normally a bit different, yaw sensors, stability and so on
But basically it's a Bosch 8 system, I don't know why you scanner will not connect to it
Fiat is listed in the instruction
Does it power on
Does it scan the engine module
