alphatangocharlie
- Jul 4, 2012
- 3
- 2
Hi all,
Today I decided to replace the parents 2005 Panda 1.1 timing belt...they have done 100,000Km's and never had it changed.
I stripped out everything that I needed to, took off the aux drive belt, took off the crankshaft pully, timing belt cover, and engine mounts.
The belt it'self looks in quite good condition, but needs to be changed alright.
My problem is, im having difficulty finding TDC with the marks on the aux crankshaft pully, crankshaft, and cam pully. I can clearly see the marks on the pullys, but there seems to be nothing to align them with.
On the camshaft pully, the line seems to line up with a "grove" just below the rocker cover seal. It looks to be at the 8 o clock position. The grove is quite wide though, 8-9mm. Is this the wrong thing to be lining up?
It's the same on the crankshaft pully. I can clearly see the line on the pully, but I can't see anything on the timing belt metal case to line it up with. It seems like it should line up with a mark on the angled piece of metal (from the haynes manual) but again...i cant see a groove.
Finally, I see there is a groove on the aux crankshaft pully that should help find TDC. After a few minutes searching for something to lign up to, i gave up.
I re-attached everything and made the car driveable again...hopefully someone here can offer some advice and I can try again! I looked at the panda classic guide to timing belt change, but the pullys seem to be a little bit different.
Any Ideas?
Any Ideas?
