Hi Simon.
Have had the same prob, so had to drive "up mendip" to see my bruv, who is a mechanic.Ahhhh
It is most likely to be one of the linkage cables for the gears, which could be as a result of several things.
(technical description from mechanics, "up and downy one" as opposed to the "side to sidey one". lol):chin:
- 'Boot' on end of cable (at gearbox end) damage, muck getting in, corrosion to cable
- Wear & Tear, with the nylon covering inside the cable sheath breaking down (between the black outer, and the cable itself) happens a lot, to other cars/vans too
- Boot under gear stick damage (most unlikely) and muck getting in.
Had to give Fiat dealers a call, linkage cables sold in pairs and was quoted £144 for the pair
<btw: If anyone knows of cheaper, I would love to know>
Anyhoo, certain amount of WD-40ing on the cable underneath(2 man job, one under squirting cable (might want goggles) as one moves gear stick) then the same under the gear stick boot (you have to pop 'boots' off, so that oil goes in) and mine is now a lot lot better, although not as it was....
So I do realise that I will need new 'uns, simply because I don't want them snapping, leaving me without gears!
Am told that replacing cables is easy to do, but £144!!! they aint much more than what you'd have on your bike.
