Hi Friends,
I have posted this post previously on Panda (Classic) forum.
My mistake..
I have a sequential LPG injection in my Panda 1.1 2005. It works very good, car goes without problems many weeks, months, but sometimes car won't start on petrol (octane).
I have to turn engine 5, 6 minutes and after that engine starts and works PERFECTLY. If engine starts, works about 30 seconds, stops again. Next start is easier but not immediatelly as well.
Next day engine starts after few turns, and works very good from start.
This was the same in August - about 15 C deg morning, and now - about -5 C deg morning.
Many servicemans said that this is because of LPG installed in car.
Is it true?
And WHY next day engine starts without any problems and works good many weeks?
Is it possible that my ECU (Magneti Marreli 4AF/4EF/59F/5AF EOBD INJ) "seens" LPG and changes start parameters?
I have checked many times petrol pressure befor firing car. After pressing a valve on the bar, petrol goes very high. Fiat ECUscan software (free version) shows good pressure as well and no errors. Only exception - sometimes missfire only error - this is clear - engine won't start.
Please help me - if ECU parameters may changes while using LPG, I will buy full version of ECUScan and I will do autoadaptation myself each month. But I would like to know that this is true ( I don't belive in it - many of my friends using LPG in Toyota's, Audi's, Opel's and everything is ok.
I have checked two different LPG injection software in the same hardware - the same effect.
While engine works on idle, petrol injection times on petrol are very similar to petrol injection times on LPG. Differences are not bigger than 5 percent.
Any suggestions and/or knowledge about this ECU?
Thank you in advance for help
Regards
Mariusz
My mistake..
Is it true?
Regards
Mariusz
