chauspain
Member
Hi mates!
Leaving work earlier I popped the 100HP into reverse to pull out of the space and just as I was releasing the clutch the car lurched backwards at an alarming rate!
Was using very little throttle and I'd hardly moved the clutch pedal off the carpet but the car just flew. I stopped sharply and tried to move back neutral but the lever was stuck and wouldn't move at all.
Shut the car off and it was stuck for a good few minutes and too quite a lot of cajoling to get it back into neutral. Hasn't happened again since I left, but that was only about a hour and I've only reversed a couple of times since.
Just wondered if anyone else has experienced this? Pretty concerning but I want to see if it will happen again before taking it to a dealer unless anyone has any advice.
Cheers!
Cheers!
