TimH
Fiat appear to have a problem with the Panda Dualogic gearbox on March and April 05 registered models. My Eleganza Dualogic has been back to the dealer on no less than 6 occasions to have the Dualogic software reloaded - it lasts about 4 to 5 weeks then appears to lose the code resulting in an almost undriveable vehicle. The symptoms are that the clutch engages as soon as the slightest amount of throttle is applied and before the engine revs have risen from tickover. The Gearbox ECU detects that the clutch has engaged to early and disengages only to enage again as you open the throttle a little further - result the car kangaroos forwards or backwards in an L driver manner! So far all this has been covered under warranty bit Fiat still have not found a solution. Has anyone else had a similar problem with the Dualogic?
