- Jul 13, 2020
- 18
- 9
Inspired by this thread I fitted a Denali Soundbomb last night, very similar in design.
Access panel in the wheel arch makes things relatively straightforward, although it's bit of a pain tightening the nut for the new horn - not enough room to get a ratchet in, and not much clearance for a spanner. Swearing a lot helped.
Just enough room to the fit the Denali in place, although I moved some wires to make life easier. Had to remove the mount and drill out the hole a little (M6 stock -> M8 for the Denali).
Will probably go back and replace the relay with a waterproof socket at some point for peace of mind.
It's loud as ****! A properly noisy honk; looking forward to telling the next boy racer who cuts me up where to stick it
