For the previous model (169) 4x4, Fiat used the same jack as the 'standard' car but supplied a 50mm thick plastic block to use with it (which was a bit wobbly!). For the newer (post 2012) Panda, the 4x4 is supplied with a jack that is bigger than that used on the regular models -marked as being for the Panda 4x4 and Qubo models only. Given that the newer car is rather heavier than the old 169 model, perhaps best to use the correct jack.
(Conversely, in case you were asking the other way round, yes, you could lift an older 4x4 using the jack from the newer one)
