Old 14-08-2019   #1
Multipla156 has donated!
Panda TA 4x4 gear selection problems
Our Panda T/A 4 x 4 is developing gear selection problems. It is is sometimes very difficult to get into and out of 1st gear and second too. Lever resistant to get into gear, feels like a mechanical resistance. Are there any known common problems?
Incidentally its done around 45k miles and (hideously) the engine has already been out with a serious issue that I should also report to Fiat - the balance shaft actually sheared, which should be practically impossible, and I think has to have been an issue related to poor manufacturing but how do i prove that?!
Thanks for your thoughts.
Multipla156 is offline Reply With Quote Quote
Old 19-08-2019   #2
Re: Panda TA 4x4 gear selection problems
Is your clutch pedal getting low? We have an issue with our clutch pedal dropping slowly. Putting your foot under the pedal and pulling it back up solves the problem for a week or 2... When the pedal got low the clutch would not disengage properly and we'd crunch gears (your problem does sound a little different).
Someone else on here had the same issue. Solved by changing the master cylinder. We've had the slave cylinder changed with no effect. I've got to book it back in for the master cylinder change. Argh...
HTH
Steve
Steve67GTV is offline Reply With Quote Quote
Old 29-08-2019   #3
hi i have the same problem with my 2015, 65 plate panda cross 4x4 i have just put the vehicle in for service, the mechanic has informed me today its the master cylinder that has failed, also the front flexible exhaust pipe is leaking, my panda has only 34000 miles on the clock, the leaking exhaust pipe i have been informed costs 750 pounds to replace ridiculous price, i am currently taking up this matter with fiat directly as i think both components should have at least lasted for five years, i just hope the problem has now been solved, i dont really want another 1700 pound service bill ouch!!! i hope this helps regards paul
Likes Shaston liked this post
panda paul is offline Reply With Quote Quote
Old 29-08-2019   #4
Quote Originally Posted by panda paul View Post
Ouch! That is indeed a ridiculous price for a flexi. Have you asked a specialist exhaust fabricator (so not Kr@pFit) for a quote?
Barchetta LE (no 2468), 1998, Silver with Red Hood/Leather, Hardtop, Wind-stop, Novitec SS Exhaust
Panda Cross Twinair, 15 Reg, in glorious Yellow
Talbot-Matra Murena 2.2 (Prep 142), 1983, Aquamarine
gar074 is offline Reply With Quote Quote
Old 29-08-2019   #5
I'll share my experiences with a 4x4 TA gear selection issue;
Local guy (technician not main dealer) diagnosed (initially) gear shift cables (relatively cheap) but then found clutch and dual mass flywheel (DMF) failure. That fixed it! I'll hope that the master cylinder is the solution for you.
On the exhaust flexi; my Alfa 147 had similar problem fixed by Jamie Porter with replacement flexi joint (search them) can be clamped or welded easy fix and reliable. I don't believe you have to replace the system in this case.
Panda IIs is offline Reply With Quote Quote
Old 30-08-2019   #6
Thanks for your replies - I'm reasonably sure it's not hydraulic - pedal seems OK and doesn't pump up - or even cable related as I've now diagnosed that it engages when the engine is idling / low revs, but if it is revving, it is difficult to select or just wont. It's at a local garage today - The garage that took the engine out and replaced the sheared balance shaft..) they think it may be clutch on the way out / clutch drag. The thing is, the engine seems to be vibrating badly too now. It has only done 55k miles...
Hmm!
Old 05-09-2019   #7
so....it has been diagnosed as the DMF - and indeed the car / engine started vibrating badly. Gearbox is now out and another problem....look at the wear on the end of the input shaft tube - in theory worn away by the DMF (apparently the middle of the DMF appears off centre? Does this make sense / anyone come across this???
Somewhat frustrated to say the least!
Name:	bellhousing tube wear.jpg
Old 06-09-2019   #8
chris3234 has donated!
Quote Originally Posted by Multipla156 View Post
Unfortunately it seems to be semi common issue with dmfs fail the extra vibration and movement damages the gearbox
chris3234 is offline Reply With Quote Quote
Old 06-09-2019   #9
Question: I read somewhere that the 85hp variant of the Panda TwinAir doesn’t have a DMF - is that true?
I would imagine it would have one for all versions of the vibey twin-pot?
Panda 4x4 TA Antarctica is offline Reply With Quote Quote
Help - gear selection problems! Flyingpunto07 Newbie Central 1 23-05-2017 21:05
(G) 4x4 gear selection problem S33 Panda (2012+) 12 18-08-2013 19:37
(T) Gear Selection Problems GPuntoW Grande Punto 0 29-05-2013 18:06
Gear selection problems Paull FIAT Boo Archives 8 13-09-2010 19:14
(T) Gear Selection Problems scrappydog Bravo / Brava 1 16-07-2003 15:54
