babbo_umbro
Established member
13-reg 4x4 TA. After sitting in the Umbrian sun for a while the temperature read-out on the dash registered 40 degrees (it was b----y hot) when I started the engine. Since then the temperature reading has clearly been faulty, generally quite a few degrees low but appearing to go up, or down, with the conditions, and sometimes seems about right. I'm assuming thr sensor is up the spout and will have it replaced. A couple of queries. Is the sensor in the left-hand door mirror as it was on the previous model? As I have plain aircon, rather than auto climate control, I assume there are no implications for the aircon function (which has worked very well during June when temperatures in central Italy were around or above 40 every day), but is there any input from this function to the engine management, or does it pick up info on ambient temperature from elsewhere - the TA engine is much more economical when the weather's hot?
