Hi.
The Fiat canbus system is far more sensitive than the one in my old Rover 75 and the error free LED's that worked OK in the 75 cause the triangle to light up and a "check number plate light" to come on, I've paralleled a 75 ohm across each bulb to no effect so in all I have 37.5 ohms in the circuit plus the already error free bulbs.
Before I lower the value any further has anyone fitted a suitable resistor to clear the error message?
To replicate the filament bulbs (when hot) I'd need to go as low as 15 ohms of at least 10 watts, so a fairly hefty resistor, if the canbus doesn't show one filament bulb out then my 37.5 ohms isn't that far out.
