Albert Alfvag
Member
Hello guys. My panda 4x4 88 is giving me a bit of a head ache.
What it does is this. When I start the car and drives off everything is fine usually, but after driving for a while the car may start to "cough" i.e. missfire or **** up the timing for maybe two to four seconds. Sometimes during this I loose all throttle respons untill I lift my foot and put it back on the accelerator.
This usually happens when going uphill or trying to accelerate at a slight incline. Can occur while just driving too,usually in the higher gears.
One more thing is that this doesn't happen every time I drive. Sometimes it's fine and sometimes the problem starts when I first drive off. I'm pretty sure I could force the problem to occur though, by trying to accelerate hard. (since this **** started I just accelerate very slowly especially uphill).
Does anyone know what this might be?
I have checked the vacuum unit on the distributer and it's fine, and I changed the sparkplugs and leads a few months ago.
I know for a fact that my thermostat is broken because the car never reaches proper running temp so one of those is on it's way.
Mind you I have the fuel injected model. The full name on mine is Fiat Panda 4x4 ie cat.
Thanks guys
/Albert
Thanks guys
/Albert
