Ok thank you,, it's going in garage on Monday,,
depending where you are, da motors in wickford charged me 250 a couple of years back for labour, i supplied the clutch and they welded up my dmf (effectively becoming a smf). The only thing is the engine has more of a diesel clatter, but is a lot quicker of the mark as the dmf isnt absorbing power.
the bite is a lot sharper as well.
It was the clutch and flywheel,, is going to cost around £500 with labour.... Ouch
tbh if they are replacing clutch and dmf and that is inc labour then that is a cracking deal, the dmf are around 250 on thier own, clutch kit about 150, so there charging approx 100 in labour going by those approx prices.
I would bite thier hands off and get it written quote.
roy
the flywheel was probably o.k. until you scratched/ scored it with a worn-out clutch.. lesson learned..!,
Charlie
