59 Plate Grande Punto electric window fault.
Robizthewizz
Hi everyone, I'm new here. been trying to rectify a problem with my electric windows. When I try to activate either of the windows from the driver side door switches, neither side will work. When I activate the passenger window from the passenger side door switch, that side works. Is there a separate fuse for the driver side or is it a different problem altogether? I've tried looking at the fuse boxes but can't seem to work out which fuse it might be. Kind thanks in advance :)
Rob
Rob
I had this problem with my Punt 07 back in the summer, after checking door hinges I traced it to a bad drivers side switch, I replaced drivers side and passenger side switches to be on the safe side. I sourced them online secondhand for £17.00 for the pair. Installed them and it sorted my window as it was stuck halfway open at the time....
