code 3164Hi, I've just bought a Fiat Punto 1.2 secondhand and the garage doesn't have the code for the radio/cassette player. The numbers on the sticker on the radio are:
7649373316
BP937345978117
021426
Please can someone let me know the code? I've just made a donation, if you need any more info please let me know.
Many thanks,
Becks
Hi got a cd player blaupunkt off eBay but no code so I've entered all reference numbers I can find on it below any help would be great many thanks xxx Stacey
BP Nr- 7642375316 on top
Prod Nr fiat- 735337934 on top
On the side- 7642375316
And 815 BP237534093901
code 4512 +(immo)Hi the link for the donation isnt working??? thanks
yes thats the right code for that serial. what was on the display?
This stereo is specifically coded to the engine immobiliser system of the vehicle it came out of using the very sophisticated CAN-BUS system technology. When it is first powered up, it will communicate with the engine immobiliser, and a message of "WAIT" will appear whilst this process is in operation. If communication has been successfull, it will prompt for the code to be entered.At the moment it says the following;
RADIO BLOCKED / WAIT
Update: It then after a while of leaving the ignition on said;
Enter Code _ _ _ _
When I entered 3143 it now says the same as above (blocked / wait)
Any ideas?
right.. codes found are as follows.
RH Side...
Visteon Part Number 2FCF-18C838JA
SERIAL NUMBER M026396
FIAT PART NUMBER 735374218
Top Sticker
FIAT OB 735374218
M026396
Not sure if this info is what you need, this is all I have..
Do you know if I can re-set the time between entries? I am now at 2hours between code inputs. due to a meddling other half and nimble fingered child...
Your thoughts on the above will be well appreciated..
Thanks in advance..
Angry Dad![]()
Hi
The numbers I gave are on the labels. There is another number stamped on the side of the case which is BP333142215528
