The one and only code for fiat radio thread.
Hello there !! I have the same problem...my radio blocked an i dont have the code...Could you please help me ? All the facts i have are those
BP - Nr. 7 647 389 316
Fiat-Nr. 735 452 486 0
Do you need anything else ?
you need more information on this one another number starts with bp and 12 numbers like this BP124578956324 hope this help you also have to donate to the forum for the code (y)
Hello, I recently had my car's battery replaced with a new one. Thus now I need the radio code which I unfortunately don't have. I hope you can help me with this.
BOSH FIAT 310 MP3 BSA HIGH
part no: 7 647 393 316
Serial no: 815CM739395906868
That's about all the information I could get from the sticker on the radio. Thanks in advance!
I have a second hand radio with which I hope to replace my existing unit that has a faulty CD player but no code for the replacement radio. Haven't tried plugging it in to the van as I don't want to risk needing the code for the currently installed unit (CD fault) for which I also don't have a code!
On the radio :-
Written - Expert 09
Stickers - DC13639 & AG063
Barcoded sticker - SIEMENS VDO
VDAPVF70228148
96 639 628 XT 00
PSARCD411-53
A2C53239143
Any good for getting the code?
hi are you sure that it's Bosh not Blaupunkt i think they only fit Blaupunkt. if it's Blaupunkt you need another code of the radio it should look like this 815BP632376113803
check your name and number site rules you need to donate to the site before getting the code 3441 may work but not sure whether it's right because it bosh let me know cheers craig (y)(n)(y)
On the radio :-
Written - Expert 09
VDAPVF70228148
96 639 628 XT 00
PSARCD411-53
A2C53239143
whats the make of the cd player fiat only use Blaupunkt and none of those code are of a Blaupunkt. if it Blaupunkt you need seial number starts with 76 and Blaupunkt start with bpand 12 numbers some time have 3 number before bp hope this hleps
you need something that looks like this
Part No 7646323316
Serial Number 815BP632376113803
(y)
Hi Darren
Please could you get me the codes for 2 panda radios (I think one is broken but I'd like to try and fix it, the other is the temporary one I am lending while I try!)
First one:
BP Nr: 7643385316
Prod no. 735 360 922
Fiat 169 CD 7 643 385 316
BP338548929998
Second one:
BP Nr: 7646386316
Prod Nr: 7354349529
Fiat 169 C1V2MP3 7646386316
BP638675774374
Further donation on its way.
Regards
Irc
5356
6331
hope this help cheers craig(y)(y)
Part No 7646323316
(y)
My guess is it's a Siemens unit fitted to a Scudo (given the mention of Expert, as in - the Peugeot badged Scudo).
Aah, this may the wrong forum!
Written on the radio is 'Expert 09' so I must assume that it came from a Pergeot Expert not a Fiat.
Now where do I go??
Hello I am new on the forum and made a donation to the forum. I have a problem with the cdc Blaupunt in the fiat punto 2003 from my daugther. All the papers are there except the ID card :-(
The numbers are:
BP915034446749
7607769150
I hope you can give me the code.
The numbers are:
BP915034446749
7607769150
hi thanks for the donation if doing again please dont be Anonymous much harder to find. after you have made a donation and you then get under your name donated member much easier to seen
https://www.fiatforum.com/donations.php
cheers
code should be 5413 (y) any problem come back to me
hi i am fairly new to this site myself i am happy to help with radio code but i do this for free and do not guarantee that they work and you use them at your own risk
i have done lots of code but sometime one out of hundred doesn't seem to work whether i have had the wrong number i'm not sure please check your number before listing (y)
site rules ask for a donation before code are given, i dont want to upset the site and get kicked off for any reason i'm the same as most people on here and i also look for answer on my problems this is my way of giving back to the site (y)
this is where you donate to the forum remember this forum is great and i think we all get loads of help so worth keeping it going
please dont donate Anonymously as it can't be seen by me i need your user name to see if you have donated you can donate as little or as much as you want as long as you donate thanks for the understanding and the help i get on this site cheers craig :worship::worship:
