Location of filter and removal of panel
The pollen filter is located behind the driver's side centre console panel almost in line with the clutch pedal
Remove the panel which is just held by securing pins.
The filter cover is a small panel around 3cm by 20cm almost in line with the clutch pedal and it's held in by two plastic spring clips and a Philips securing screw underneath.
Here's the two plastic spring clips and the location of the securing screw.
The cover then pushes off towards the front of the car
