Removing rear seat
Then all that is left is to take out the back of the rear seat; NB: you might not have to do this if you are carefully at angeling out the rear panel, but i found it was a pain and was easy just to take it out! This comes out as 1 whole piece, not like the bases that come out as two pieces! To take the back of the rear seat out you will need to un-bolt the bolts along the back of the seat in the boot, you will see these by lifting up the boot mat! Then you you also need to un-bolt some from other side; which have the seat belt clipy things attached to them as well!
