Bumper removal
The antenna sticks to the bumper, there is no access to the bumper to fit the kit so it needs to be removed
There are 10 bolts/screws to remove
To Start there are 4x Torx bolts that are literally on the lip of the bumper as you open the boot.
There are 2x of the same torx bolts underneath anchoring the bottom down. easily seen when you look under the car
Each side then has a 8mm and 10mm nut/screw this can be seen here on the bumpers cut out holes
The hidden bumper versions i used a long extension which helped no end
On the mk2b there is no splash guards, where as the mk2 there is. Its not hard to remove a few extra screws and nuts to remove this cover.
Don't forget the numberplate light as well - it needs to be disconnected before pulling the bumper 100% free. A simple twist and pull
Now i like clean, when i pulled it off there was 9 years of road grime, since the bumper is not coming off again, i gave it a quick sponge wash
