While you had the air filter assembly off the top of the engine did you check the large and small tube that run from the filter to the top of the engine? They rot and at current age unless they're been replaced with updated versions they will have rotted through letting oil over the top of the engine and causing running problems
Hi DGPunto,
thanks for your opinion. Today I had some spare time so I decided to have a look under the airbox.
So, as shown in the pics, I found a cut in the small hose that goes from I don't know where (??), into the airbox. It was fixed with some tape.
Which is the scope of this pipe and where I can buy it?
Then, I cleaned the throttle body and the MAP sensor. Also, I checked the purge valve solenoid with a multimeter getting the value of 19-20 Ohm. I'm not able to find anywhere if this range is it the correct one. Does anyone know it?
My question now is: could that broken hose cause a misfire only when the tank is full for more than a quarter?
Thanks to all! Hope to be close to the problem
