Hi guys,
My apologies for my first post being questions, but I hope to find a shining light on what may be the issue, or maybe the car has to be totaled.
I bought it in May, a 2007 sport model, ran fine although sometimes it had rough idle for the first 20secs. Power was good and didnt get a hiccup. It had a p0301 (cil 1 misifre) once when I pushed it when cold, it stalled.
Last weekend I was driving home and I suddenly lost power trying to go above 110kmh. Shaking and engine light, same error core. I limped it home. Since then it also doesn't sound quite right when dricing / idling (only for testing). No knocking but tapping / camshaft noise I think (not sure). Also worth mentioningrg: last oil replace had a few big oarts of metal in it, but not bearing material. Was adviced to change the oil again and keep driving as it ran fine. So I did that.
What I have done:
Changed al the spark plug (ngk iridum as spec).
Replaced cil 1 lead.
Swapped all plugs & leads but the code stays the same: misfire cylinder one.
Checked compression cil 1: 170, cil 2: 185 (didnt check the other yet, seems fine.
Spark cil 1 sometimes seems good, sometimes didn't, so:
Changed the Ecu ( after all this I figured this had to be it, but no such luck).
I'm at my wits end. I can swap injectors maybe but otherwise I'm getting ready to tow it to my friend who owns a shop. I was hoping to find any insights here and hope the car is not lost.
Any suggestions are welcome, thanks in advance.
B
What I have done:
B
