Hey, have a 2010 Fiat Punto Grande Sound on a 1.4 engine.
Did a 200 mile drive recently and towards the end I noticed a slight judder / rock in the engine whilst stationary.
Next day drove to the local shop, and had the engine judder again but more heavily whilst doing 20 in third gear.
Day after engine management light came on, solid amber.
Plugged it into the diagnostics and has come back with this -
P0300 [0x0300]
Random/multiple cylinder(s) - misfire detected
Status: Confirmed
P0301 [0x0301]
Cylinder 1 - misfire detected
Status: Confirmed
The misfire seems to be intermittent. I've replaced the coil pack and cleared code but it's come back straight away. Last service was two years ago.
Could it be spark plugs or cable? Unfortunately they're too short to swap over on the coil pack. And I'd need to get tools if I were to have a go..
Someone mentioned the possibility of a coil pack / ecu failure but from my research this is on the Mk2 models with a 2 cylinder misfire? Correct me if I'm wrong.
Please let me know if there's anything else i should check. If it's something I can do myself before taking it to a mechanic, then I'd rather do that!
P0300 [0x0300]
Status: Confirmed
P0301 [0x0301]
Status: Confirmed
