im Axle Specialists
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Grande Punto Engine bay Earthing Points<!-- google_ad_section_end -->
Quick guide showing the locations of the Major earthing points in the GP's engine bay
Published by Andy Monty
13-11-2008
Difficulty Level: 1
User Rated:
Difficulty Level: 2
Tools needed
13mm socket and a LONG extension bar or 2 and T brace (13mm combination spanner will do at a push although one earth point NEEDS a 13mm socket)
a 10mm socket and small ratchet
fine Emmery paper /wire wool
small wire brush
Some kind of grease or petrolium jelly (Vaseline)
its a simple matter of removing each earth wire, cleaning both the crimped on ring and the landing point on the car and contact point of the nut and thread on the post using a combination of the Emmery paper and wire brush putting back together then giving a good coat of grease to seal out the water...
there are four that i have found in the engine bay the Green spots give their approximate location
Lets start with the easy ones
(disconnect the earth at the battery before you go any further)
there are 2 earths under the ABS modulator
close up
both of these are held in place by a 10mm nut
now onto the one which is located on the leg chassis leg on the opposite side to the screen wash water bottle
this is held in place by a 13mm nut but has a plastic shroud around it so only a socket will fit
And finally saving the most difficult for last...
The gearbox earth strap....
First of all
use a 13mm socket to loosen both gold clutch actuator bolts
once loose remove one completely..
now with one hand hold the clutch actuator and with the other remove the last bolt
once loose the actuator will be trying to push back keep hold of it and move gently to one side and use one of the bolts to secure it to the opposite hole if it extends too far you will need to bleed the clutch
now remove nut with a 13mm socket
and re fit in reverse order take care not to over tighten the clutch actuator (its only plastic)
lastly reconnect the battery
hope this helps
Thanks oldmanhouse, Turtle, Thomas_Si thanked for this post
Likes nikrox, Turtle liked this post
Old 30-12-2012   #1
Re: Grande Punto Engine bay Earthing Points
When I fitted my HID's i just connected the lines to the battery terminal and it worked fine. Or is this something else?
grantm616 is offline Reply With Quote Quote
Old 02-01-2015   #2
KBonnie has donated!
Anybody know where the earthing points are on a sporting as there's quite a bit more in the engine bay than in the pictures shown. Preferably the earthing points on the 1.9 mjet.
KBonnie is offline Reply With Quote Quote
Old 02-01-2015   #3
Moderator
Andy Monty's Avatar
Andy Monty has donated!
For what item?
Old 02-01-2015   #4
As much as I know this will go down like a lead balloon with some people. Its for a HID kit.
Old 24-08-2015   #5
haha still no reply 7 months later. Not seen you on here much recently mate?
im on instagram (sometimes) @tjscotton
if your contemplating new wheels/colour change etc let me know and i'll be happy to do you a photoshop so you can see what it looks like
tjscotton is offline Reply With Quote Quote
Old 11-08-2017   #6
A couple of years back I had the dashboard lights go out and thought it was probably the earth. So I just ran a duplicate lead across to the engine.
Poking around today I found the old earth lead in this state.
OldEngineer is offline Reply With Quote Quote
Old 20-05-2019   #7
In my past life many moons ago, she said the choke does'nt work.
BMC 1100, earth strap broken so engine earths thru choke, throttle, heater, speedo cable and anything else!!!
puntodad19 is offline Reply With Quote Quote
Old 16-01-2021   #8
nikrox has donated!
I spent a cold,frustrating hour or so yesterday taking the nuts off and cleaning the rust/smeg off the two earth points under the abs unit..pleasing to know they are now sorted.
Gave up looking for the one on the opposite leg though.
Where is the starter motor on a 1.4 GP? I was advised that the connection is also a common fail point too...
nikrox is offline Reply With Quote Quote
Comment
Search this Guide:
(T) Punto JTD engine earthing strap mars103 Punto (Mk2/2b) 1 25-09-2008 10:20
(T) earthing points on MK2 Punto - PLEASE! kennethsross Punto (Mk2/2b) 3 26-06-2008 20:52
(T) how many earthing points bulgarianbarchetta Barchetta 3 19-04-2008 18:34
(G) Earthing points Alan.D Panda (Classic) 2 27-01-2007 10:17
