Guys :-( My happiness is over ;-( Today I checked oil and there were non-metalic particles on dipstick. Almost quarter of dipstick was covered with it. Like old burned oil. So engine is still not clean after that overheating. During 1,5 years there is 3rd oil, once also flushed with flush agent. Oil is also leaking a little bit somewhere between engine and gearbox, but it's like a thin film on oil pan, no drops on ground. But rear crank seal was replaced with new one, oil pan re-sealed. Cannot determine if its gold or red...its just dirty. Oil level also surprised me because 0.5 year ago when I did oil change I gave there to MAX on dipstick, and now is slightly above MIN. But I have no smoke from exhaust.
So, I will not ride the car. As 1st I have to drain it abd analyze whats in the oil. I'll also check variator valve for deposits on it's sifters.
Then I'll make double flush with diesel. Yes, double flush, each time to change filter. Because that debris can damage good parts.
Looks that engine is still cleaning itself...as it heals from that strange ticking on hot idle, its still healing from burned oil.
And if this doesnt help, I'll sell this car with huge money lost :-(
General repair will be very expensive and there was changed at least one exhaust valve as I discovered earlier, so I believe that cylinder head was grinded one time. Not sure if it can be grinded twice. So general repair is not way for me.
Guys, what is the best solution here to flush whole engine properly and withou causing any damage to seals? Is diesel ok for this?
