Thread Tools
Old 1 Week Ago   #1
Handbrake cable
Hi guys, I have a problem with the handbrake,
Ive noticed the O/S doesnít lock, I took the handbrake cover off because I thought it might be a snapped cable, but itís not a snapped cable but this, the O/S cable is longer than the N/S,
I jacked the car up and I slightly put some tension on the cable and I noticed the O/S wheel did lock, so the cable seems fine it just seems slack, this brings me to the next picture, the left cable is the O/S wheel, there looks like there is some sort of threaded screw, would I be correct in saying if I unwind this threaded screw will it put tension on the cable? Because on the N/S cable I canít see any threads?
My other concern is, as you can see the cables are different lengths, would all this be caused by worn brake shoes? Or just the handbrake not being set up properly from previous owner?
Liam1804 is offline Reply With Quote Quote
Old 1 Week Ago   #2
Slovakia
Re: Handbrake cable
I never saw Puntos handbrake mechanism, but in other cars there were always 2 cables with same look and same lenght... but maybe Punto is specific...
Rado77 is offline Reply With Quote Quote
Old 1 Week Ago   #3
chris3234 has donated!
Re: Handbrake cable
Tha adjuster is for both cables not just one
If you have tension on one cable and not the other you problem is likely at the drum end probably the auto adjusters arnt working and correcting for the wear in the shoes
chris3234 is offline Reply With Quote Quote
Old 1 Week Ago   #4
Quote Originally Posted by chris3234 View Post
Not the adjuster, if you look at the 2nd pic weíre the cable comes into the car there seems to be what looks like a threaded bolt, thatís what it felt like anyway, Iíll take another look tomorrow, maybe one of the rubber mountings has come lose, failing that Iíll have a look at the shoes
Old 1 Week Ago   #5
Re: Handbrake cable
This is what it looks like. Your cable maybe snapped inside the drum. It's not a big job.
Thanks Liam1804 thanked for this post
Likes Liam1804 liked this post
SRafferty is offline Reply With Quote Quote
Old 1 Week Ago   #6
Re: Handbrake cable
Found the problem the cable wasnít snapped but the clip had broken were it clips into the body of the car by the handbrake, but after dismantling the drum the cylinder started leaking all over the shoes, so itís a new cable, shoes, and cylinder, ☹️ I have a question regarding the auto adjuster, all was ok until I took it out and started messing, now I think itís lost weíre it was set at, when I put it back together do I just wind it out so itís touching both shoes then once everything is back together pump the foot brake a few times and it will adjust itís self? First time doing drum brakes so I apologise if It sound like common sense, I appreciate all the help
Old 1 Week Ago   #7
Belgium
Re: Handbrake cable
Once the drum is reassembled, you can adjust the tooth wheel with a flat screwdriver thru one the wheel's hole. Release the hand brake hand and tight the adjuster until the shoes just get in contact with the drum. Have a look at it before reassembly and you'll figure out how it works.
BRs, Bernie
Old 1 Week Ago   #8
Re: Handbrake cable
Think Iíve hit another problem, When I was removing the handbrake cable from the brake shoe backplate there was a small clip that came out with the cable but broke because it was rusty, does this clip come with the new handbrake or is it part of the backplate?
Old 1 Week Ago   #9
varesecrazy has donated!
Quote Originally Posted by Liam1804 View Post
Photo of this clip..?
Is it just holding the head of the cable inside the drum. ??
Look on ePER for a picture: part number.
Old 1 Week Ago   #10
Quote Originally Posted by varesecrazy View Post
Had a look on ePER just gives me an error message every time I select what engine I have under brakes,
heres a pic I got online, your correct it looks like the head of the cable clips into it but looks like it was part of the backplate
Old 1 Week Ago   #11
Re: Handbrake cable
Managed to find an imagine that matches, this is for a Ford KA but it looks like the part
Likes SRafferty liked this post
Old 1 Week Ago   #12
Found out itís part number 77362446, about £20 from fiat 😲. What a total rip off for something that looks like it costs pennies, best thing is the ford one looks exactly the same. I think Iíll chance buying the ford one, they both look the same and only about £6 from ford
Old 5 Days Ago   #13
Re: Handbrake cable
Trying to fit the handbrake cable but weíre the cable enters the car there is a plastic clip with 2 tabs on to hold it to the body of the car, How the hell do you attach this to The body? Iíve tried to pushing it on, pulling on the cable hoping it will click into place, but itís having none of it
Old 1 Day Ago   #14
Re: Handbrake cable
The "bar" at the handbrake lever end is a compensator, and should be "parrallel" but as you have found the is an issue with the cable on the "slanting" side.
Have seen on other cars where the cable dissappears inside the drum, no stop for the outer cable to press against if you see what i mean.
Post a pic of the handbrake lever end with the clip issue.....
The self adjusting rachet mech must be free and lubed for it to work.....when back plate reassembled and the handbrake fully un adjusted ( it should be the first job to do when changing shoes ) , (so the shoe lever is at its stop against the shoe, the pressed in bulge on the shoe lever ) , centralise the shoes via the foot brake, you may hear the rachet working as the system centralises and self adjusts.
With the car back on the deck, a very short drive ( say 4 metres ) and pressing the foot brake will ensure shoe centralisation, do this a few timkes to make sure, then adjust the handbrake cable, but remember the wheel needs to rotate freely before the handbrake comes on.
8 clicks seems to high, mot would probably adviseory.....
puntodad19 is offline Reply With Quote Quote
Old 1 Day Ago   #15
Quote Originally Posted by puntodad19 View Post
All sorted now mate with the handbrake,
Regarding the brake shoes what I did was, I adjusted them so the drums were ever so slightly touching, put every thing back together and I pumped the footbrake about 50 times, I did here the adjusters clicking then I couldnít hear any clicking after a couple of pump on the brake, does that sound like they have adjusted correctly? Never done drum brakes before only Calipers
Thread Tools
(G) handbrake cable busboy Stilo 2 28-03-2013 09:20
(T) Handbrake Cable Punto Sam Punto (Mk2/2b) 0 23-12-2008 23:59
(T) handbrake cable pauljj40 Punto (Mk2/2b) 2 16-12-2007 15:08
(G) handbrake cable geoff750 Tempra 1 17-11-2007 11:20
(T) Handbrake cable... where does it go? GhostWKD Cinquecento / Seicento 16 07-05-2006 22:55
