MrMogensen
- Mar 6, 2018
- 38
- 12
Fan goes on/off/on/off/on/off for about 5-10 seconds just after starting the engine and turning on the fan.
It's not everytime but has happened 1-2 times during the last 5 days.
I have dual climate. Display doesn't read anything out of the ordinary. Tried to turn up the fan speed while this happened and I could hear the fan increasing speed between the "off's".
Once working (after the 5-10 seconds) the fan works normally the next 30 minutes (the max I have driven at a time this past week).
Isn't it most likely I have a soon to be faulty heater motor (and not any of the other related electrics)?
*EXTRA QUESTION*
The only thing I really hate about my GP is the A/C not being allowed to turn on once outside temp-sensor tells the car that temp is lower than 0 degrees celcious.
Thought about installing a hidden flip-switch that directs the outside temp-sensor through another resistor. In this way I would cheat the car into turning on A/C even at minus degrees celcious.
But would I be in danger of damaging the A/C system if I turned it on in like -5 degrees celcious? I would understand if FIAT didn't want me to turn on A/C if it was -20 outside but, at least for now, that seems unlikely in Denmark.
*EXTRA QUESTION*
