Old 20-11-2016   #1
Barbados
car stuck in 1st gear; cannot move or tow
Hello,
My Fiat Grande Punto 2009 developed a transmission problem yesterday. I get error code <P1773 - Hydraulic circuit pressure>. The car won't start anymore, I immediately get fault msg <check transmission> and the pump is not priming when I open the door. The car is stuck in 1st gear and I cannot get it to change to Neutral.
The car is in a bad spot on the road and I need to move it. Since it is in 1st gear, I cannot push it to the side and I understand the car cannot be towed with the gear engaged.
I there a way to get the gear in Neutral in this situation?
Thank you for any advice.
Mangoa is offline Reply With Quote Quote
Old 20-11-2016   #2
varesecrazy has donated!
Re: car stuck in 1st gear; cannot move or tow
Quote Originally Posted by Mangoa View Post
Hello,
as a quick first thing;
remove the negative BLACK lead from the engine battery,
leave disconnected for 2 hours+ ,
then reconnect,
it MAY just reset something,
had any other weird things.. or service work done lately..??
while the battery is disconnected, check the under bonnet fuseboxes are watertight,
look here..;
https://www.fiatforum.com/grande-pun...in-thread.html
Charlie
Old 20-11-2016   #3
Barbados
Hi Charlie,
Thank you for the suggestions. I checked the link.
Disconnected the battery. Will get back about that in 3 hours.
Otherwise the car was functioning well except for some CAN errors usually when there were some humidity issues; a wire is a bit exposed under the left mirror since a small body part is missing there (bought the car 2nd hand). At the moment it is very hot and sunny (I live in Barbados and it is currently early afternoon and about 34 degr.celsius) so there do not seem to be any humidity issues. I opened the fuse box and it looks clean and dry. No humidity around there either. The car is in the sun, I can hardly touch the bonnet.
I will contact the dealership tomorrow since it looks like there is a problem with the selespeed pump, but my first priority is to be able to move the car. So I need to get it in neutral.
Stefan
Old 20-11-2016   #4
Barbados
Well, battery has been disconnected for about 3.5 hours. Still the same problem. It is quite unbelievable that there is no way to get this car in neutral so it can be pushed to the side or towed. Will contact the dealership tomorrow and hope they have a solution.
Old 20-11-2016   #5
flisko has donated!
does it still crank? leave it in first gear and move it to the side with starter by cranking it
flisko is offline Reply With Quote Quote
Old 21-11-2016   #6
Barbados
No, it doesn't crank. I turn the key and no cranking, just beeping from the 'check transmission' error messages.
Old 21-11-2016   #7
The pump is triggered by opening the door.
People have had issues with damaged door wiring..
Does the interior light trigger with door opening..?
Old 21-11-2016   #8
Became old and sensible
MrDerv's Avatar
MrDerv has donated!
Quote Originally Posted by flisko View Post
Dualogic transmissions won't start unless it's in neutral.
Current Garage
Mine: 2013 VW Passat Sport BlueMotion Tech 2.0 TDI Stage 2 Mapped
Hers: 2007 Renault Megane 1.6 VVT Auto Dynamique
MrDerv is offline Reply With Quote Quote
Old 21-11-2016   #9
Barbados
Light does come on when I open the door. Contacted a towing service to take it to the dealership.
Old 21-11-2016   #10
Good luck for a simple fix..
Do let us know what is tequired.
Charlie
Old 21-11-2016   #11
Barbados
Will post an update. I keep my fingers crossed its is not the pump or actuator.
Old 21-11-2016   #12
flisko has donated!
Quote Originally Posted by brickfoot View Post
nice fail design
Old 22-11-2016   #13
MrDerv's Avatar
MrDerv has donated!
nice fail design
Not really, All Automatic transmission cars won't start unless in Park or Neutral, so hardly a design flaw or limited to the dualogic
Last thing you want is the car suddenly surging forward when you start the engine.
Current Garage
Old 22-11-2016   #14
flisko has donated!
thats how i moved my car alone when it didnt start, first gear and cranking
Old 22-11-2016   #15
that's fine when you're expecting it..,
we've all read of Americans being run over by their own cars..
(T) Car won't move in gear, no drive ScottMcKendrick Punto (Mk2/2b) 7 22-04-2014 18:49
(T) 1st and 2nd gear sounds like and electric car!!!! dereklanger Grande Punto 14 24-06-2010 06:35
(T) Car judders when clutch bites in 1st gear sshnlawson Bravo / Brava 2 12-02-2010 19:30
car judders when moving off 1st gear Lemon FIAT Boo Archives 4 05-09-2009 23:17
Car won't go into 1st or 2nd gear easily Stuart FIAT Boo Archives 3 08-11-2002 00:01
