Thread Tools
Old 20-03-2016   #1
Exclamation Fiat punto starter moter removal
Hello all,
I have recently bought a fiat grande punto 1.3L multi jet diesel 07 plate. When I first bought it, everything was fine then about 2 nights ago, the car wouldn't start although all the electrics worked fine. I had a warning light on the dash of an exclamation mark in a triangle. After the AA came out and bump started me, he said the starter motor has gone. I'm in the process of trying to remove it but cannot find any bolts or anything to undo to take it off. There is very little information in the Internet about what to do so thought I'd ask on here if anyone knows if you can do it at home or if it's a garage job to do it.
Any information would be greatly appreciated.
Thanks,
Kieran
Kiesco is offline Reply With Quote Quote
Old 20-03-2016   #2
Re: Fiat punto starter moter removal
Hi Kieran
I can relay to exactly what you are saying after doing the same job on my brothers Punto Van it is fiddly !!
Best thing to do is Jack the front of the vehicle up as the starter motor is around the back of the engine ....
There is one bolt underneath and the connections are underneath the main power is bolted via a 13mm with a plastic spacer block with the exciter behind you'll see what I mean when you remove this...
There is then one other bolt which goes through a recess in the bell housing you'll work out where it is by the shape of the new starter just note it goes the other way through hence the top part is threaded !
Hope this helps let me know how you get on buddy
Macaulay is offline Reply With Quote Quote
Old 21-03-2016   #3
Smile Re: Fiat punto starter moter removal
Hello,
Thanks for your advice. I managed to change it following your instructions. Only problem now is I don't think the starter motor is the issue. Bloody cars lol. Well back to the googling to solve the next issue.
Likes Albefjeds liked this post
Old 22-03-2016   #4
Greece
Any stored codes in the ECU ?
Check power cables/ earth points / fusebox / battery (even if it looks good)
cmosfxx is offline Reply With Quote Quote
Old 23-03-2016   #5
Ireland
Earth strap!
digger58 is offline Reply With Quote Quote
Old 08-09-2019   #6
Denmark
Quote Originally Posted by Kiesco View Post
Hello,
Hey, did you figure out what the problem was, I Think I have the same problem as you had and i canít figure it out.
Hope you can help
Albefjeds is offline Reply With Quote Quote
Old 08-09-2019   #7
nikrox has donated!
nikrox is online now Reply With Quote Quote
Old 08-09-2019   #8
Belgium
Quote Originally Posted by Albefjeds View Post
Hey, did you figure out what the problem was, I Think I have the same problem as you had and i can’t figure it out.
Hope you can help
No presentation, nothing ..., maybe a future "no-feedbacker" ?
Rgds, Bernie
Old 08-09-2019   #9
Bhutan
Post Re: Fiat punto starter moter removal
Most people are useless parasites. They don't give back to the community.
They use (abuse) forum "one-way", only extract information and then disappear.
It's time to update forum rules.
If you don't report back (problem solved or not), your topic will be erased.
It can be done manually (moderators) or as a forum function, "toggle bit" or topic "status flag".
Original poster is obligated to update within, let's say 3-6 months and flip the thread status ("topic solved"). If there is no change in status, topic is deleted automatically.
For now, this forum is "quantity" oriented (not quality of the content). Most topics not solved, and multiple threads on the same issues, started over and over again every day, without Searching (that can be checked too - if new forum user ever tried to use Search before posting).
Likes Bernievarian, kjeldio liked this post
Dislikes Frosty1961 disliked this post
Last edited by GrandePunto PL; 08-09-2019 at 17:15. Reason: Good, free idea, Use it. Make forum better.
GrandePunto PL is offline Reply With Quote Quote
Thread Tools
Grande Punto anyone got a guide to take starter moter off jurik891964 Newbie Central 3 11-11-2014 20:50
(T) Fiat punto sporting - starter motor removal Waldo99 Punto (Mk2/2b) 7 02-04-2014 17:41
(G) punto starter moter problem m1979shakil Punto (Mk2/2b) 3 09-11-2008 23:56
(G) Seicento 16v Starter Moter Q. J.R Racing Cinquecento / Seicento 23 05-02-2008 00:35
