Yellow Calx
- Jan 25, 2016
- 4
- 1
Bit of a strange issue this, one of a couple of issues with this car. They may all be related but let me describe this one first.
- I turn the key in the ignition and the car doesn't start. Engine lights come on but the starter motor doesn't turn over. Dead
- pull the gearstick over to the right and turn the key and the car fires up straight away (i discovered this by luck rather than judgement).
-turn key to off position and remove key but engine stays running until I move the gearstick over and the engine then cuts out.
-Once I've done this a couple of times the engine sort of starts turning over without doing the thing where I move the gearstick but engine is sluggish and doesn't rev, sounds similar to when you run a car minus a sparkplug.
-Engine Mil light is on and remains on.
I had this problem about 3 weeks ago but had cleared itself, warning light included, by the time I got to the car the next morning
As well as this issue I have the problem a few forum users have experienced where full beams stay on when you select dip.
I also had someone behind me flashing as if to say my rear lights weren't working or that my indicator was on but I pulled over and checked, all seemed to be working ok (!?) but i assume something was up with them.
I've read a few similar threads and the solution problem seems to be bad earth or water/corrosion in fusebox, I'll look at these when I get back to my car(car left at work as couldn't drive home with no lights or perm full beams)
Wondering if anyone has any specific input as to why the car starts perfectly when I move the gear shift to the right. Why is that?
Also hoping someone could offer guidance when checking the earths and fuses, which ones to look at etc.
Thanks in advance for any input
