Hello,
I'm a new member and this is my first post so please be understanding
Recently I noticed that when adjusting the headlight beam using the buttons on the control panel only left headlight actually is changing the slant. Nothing is happening with the right headlight. I can hear only left adjuster motor. I have never noticed in the past if both headlights were changing the slant or only just left one? Is it possible that adjustment is only on the left one and the right one keeps the same slant?
I was googeling but was not able to find definitive answer. In my other car (Seat) both headlights changing the slant.
I thought that the issue is with the fuse but in the user manual i found only fuse for the right aiming device as per the below:
Left dipped beam power, headlight aiming device - fuse 38
Right dipped beam power - fuse 39
I have two questions:
1. Is it possible that adjustment is only on the left one and the right one keeps the same slant?
2. If the adjustments should be on both headlights how to identify what is broken and how to fix it.
Many thanks in advance
