thaduck1
Hi...
So i have kind of a big/pass in the ass problem. So here goes...
It started around 2 weeks ago, the passenger side window in my car would no longer work at all, so it was stuck up.
about a week ago my drivers side window started doing the same (intermittently) but the weird thing was that i could get it to work by opening the door slightly and then pushing the button.
Then a few days later the passenger side window started working again, for like an hour.... and then broke again so now i have a passenger window that is 3 quarters of the way up and will not go up any further
I have checked the fuses and the one for the drivers side was blown, so i changed that (no difference) they still will not budge at all!
I took the plastics off the inside of the door, but im none the wiser because i couldnt really see much as there was a white sheet covering everything in the door along with a metal panel.
I really am a novice when it comes to cars so i really dont know what to do/try next... has anyone else had/solved this problem, or is there anyone who can suggest anything that may help?
Even if i could just get the window to go up until i have got the cash to get someone to have a look at it.
Thanks in advance!!
Thanks in advance!!
