I know i've started a few threads regarding this but thought it would be worth another to keep things clear etc. Anyway.
A clunking noise started, on my drivers side suspension, around 3 months ago and has been getting worse since i.e. from knocking on reversing to going round corners whilst driving. I thought it was drop links but I've had it looked at today, and apparently, it's the CV Joint (drop links are fine and the same knocking is caused when pulling on the below):
According to the garage, the problem is caused when a car is lowered and the CV joint sits in a 'V' shape causing grease etc to leak and eventually cause the problem i've got. So a couple of questions:
1.is this expensive to repair
2. if i get it fixed, will it not just happen again?
3. Why the f*** did I not see any info about this anywhere before lowering, is it not a common issue?
4. Are 'lowered CV joints' an option? I really cannot afford for things like this to happen as a result of something iv changed on the car
The other issue, causing some stupid rattling, is the exhaust sitting more or less on this bar:
Is there anything I can wrap around the bar to stop this?
How exhaust UK said there is no way its that that's is rattling just confuses me. It's obviously the only thing close to metal on metal, and I proved it by pulling on the exhaust.
Thanks in advance anyone, really appreciate any advice as the last thing I wanna do is have to put the car back on standard suspension, it would probably cost me more to do this than to leave it how it is, and with having to have a new cambelt very soon, its not a great time.
Sam
Sam
