DriGP
Hi all,
Yesterday i topped the car with coolant to MAX since it was nearly empty. Today i noticed that the reservoir is empty again the leaking only starts when the engine is on. I also noticed coolant underneath the 4th spark-plug, but cannot see exactly from where the leak is coming from. Attached are photos of the coolant found underneath the spark-plug.
Does anyone know what to do ? is it safe to drive if it is not being over-heating? and will that liquid that you mix with the coolant to seal the cracks work?
Thanks in advance.
Thanks in advance.
