Old 06-12-2009   #1
Drop links
My 06 Sporting JTD makes a very loud metal noise every time I go over bumps, when I change gear and accelerate and when I go over road undulations. I had the same problem in Feb 08, it was traced down to worn drop links which were replaced and the car was fine.
I bought the car brand new in June 06. Drop links were replaced in Feb 08 at 28k miles. The car turned 3 years old in June 09, the car has 56k miles on the clock. Are the drop links still under warranty?
georgios1976 is offline Reply With Quote Quote
Old 06-12-2009   #2
Re: Drop links
Afraid not as your is out of it's warrenty period now.. Not alot is covered in the third year dealer warrenty.
Though they only cost around 12-13 each and you can change them yourself as they are really easy to do.
1.8Stilo is offline Reply With Quote Quote
Old 06-12-2009   #3
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Drop links
9 ish from shop4parts
http://www.shop4parts.co.uk/?name=st...=2816&sku=7107
if you have the basic mechanical skills takes you about 15-30 mins a side the OEM fiat M10 nuts have a 16mm AF head size (odd ball) but you can get a 16mm socket no problem
soak the threads for a couple of days (can be done with the wheels on full lock) with decent penetrating oil I had access to an air ratchet which saved a bit of time) as the bottom one is a bit awkward to get at
its advisable to replace the nuts (i used nylocs)
only 2 nuts per side and a immsmc a 17mm open ended spanner to hold the pin to stop it turning
Massive gash
Just a little touch up
Old 06-12-2009   #4
Moderator
Andy Monty's Avatar
Re: Drop links
https://www.fiatforum.com/stilo-guid...ks-30mins.html
bare in mind the GP doesn't need an alan key
Massive gash
(T) DROP LINKS (OR ANTI ROLL BAR LINKS) - If I don't fix now is this a nightmare? PAULH Stilo 21 21-09-2009 12:57
(T) Drop Links?? I think not. driverjgp Stilo 2 17-04-2009 13:02
(G) Drop Links? lemON1 Grande Punto 17 17-04-2009 12:57
(T) Drop links loudpunto Grande Punto 5 03-04-2008 05:37
