- May 25, 2006
- 16,219
- 2,029
Nah its too late to bring that one out. They should replace them under warrenty as you wouldnt expect a starter to pack up within warrenty from "normal" use.
yes had the head fiat bloke out at the dealership and he says its a starter moter issue and not sending right charge something like that ...
? How did he explain the starter motor works all-day-&-every-day but not first sparrows cough?
yes had the head fiat bloke out at the dealership and he says its ...
Just read treadstone's thread (Non starts when cold) & that seems to fit with the problem (certainly mine) ... put down to an air temp sensor fault.
GP 1.2/8v 56(2006Dec) 25K ml & having similar experience since the cold snap. Always fires 1st time but won't hold any revs - have to start-over 4/5 times with some throttle tickle (outside of starting guidelines) before holding revs ... it's like there is no auto-choke(?) Temp dial zooms to max then back to around 1/8th from cold. No problem later in the day.
any news or progress mate?i didnt have any turnover atall Caravadossi no engine start and intermittent. dash light up but failed start. so no chugging noise
they now say its wireing/loose connection or fuse /ampage issue and not the starter moter ?
because its intermittent they still need more test and failures to be sure. they may have fixed the problem already they say by removing fuse boxes ect.
they didnt mention the power steering failure and like a idiot i forgot to ask, was more interested if 3rd year warrenty covered cost.
anyone know whats covered in 3rd year its a bit sketchy like official secrets act i cant find a list anywhere just a summery.
may have car back tommorow ? ill keep you posted
This is a side question, but does the cover you usually get to drive other cars with fully-comp insurance not cover courtesy cars?
dealer states they dont get paid for fault finding by the insurer only fixing it, if the part is covered?
is this true ?.
