Old 16-12-2008   #1
Top Dog
Tris Harris's Avatar
Trader Rating: 1
Tris Harris has donated!
Unhappy Seatbelt holder rattle
Hi all,
my seatbelt holders rattle like crazy whenever you go over a bump (with the seatbelts clipped in). Doesn't happen if the seatbelt is in the holder at a certain angle ie, fat person in seat, or seat pushed far forward.
Does anyone else have this problem? It's both the passenger and drivers side that does it. It's doing my head in, but can't be bothered with Fiat saying they can't do anything about it... any idea's?
Tris Harris is offline Reply With Quote Quote
Old 16-12-2008   #2
Dub Dub Dub
Aircooledbug has donated!
Re: Seatbelt holder rattle
Only rattles when tilted.... obviously something becomes loose when tilted... does it happen when you shake it?
2006 Caribbean Orange 1.9 Multijet 130
Aircooledbug is offline Reply With Quote Quote
Old 16-12-2008   #3
Top Dog
Trader Rating: 1
Quote Originally Posted by LeePunto1.9 View Post
when you shake the actual seatbelt (while clipped in) rather than the holder yes.
When the seatbelt is not in, it's fine
Old 16-12-2008   #4
Dub Dub Dub
something must be loose inside it... id say open it but springs would probably fly everywhere! lol
Old 16-12-2008   #5
Moderator
Andy Monty's Avatar
Andy Monty has donated!
It didn't rattle when i was in the car with you
As tris says the buckle and clip rattle when the belt is "loose" on his mine doesn't
Massive gash
Just a little touch up
Old 16-12-2008   #6
Top Dog
Trader Rating: 1
haha yeah, i'd be finding bits for weeks
Quote Originally Posted by Andy Monty View Post
looks like its a Fiat jobby
Old 16-12-2008   #7
I've got something like this happening at the back to from the seat belts. Sounds like the seat belt locking, you know when you stop hardish. Drives me mental.
Reece
reecey_p is offline Reply With Quote Quote
Old 17-12-2008   #8
Greece
Quote Originally Posted by Tris Harris View Post
Hi all,
goodmorning my friend. my bach seatbelt from the co-drivers side couldn;t fastened. i took the decision to open it and see inside. if you try to open it note that you should do it from the bottom of the plastic cover.if you go from the top it will look ugly because you will have to use a screwdriver or something similar and will create scratches and cuts to the cover.anyway it is bolted by 3 melted plastic trims inside.two above and one on top. you will see that inside there is no obvious screws.fiat can replace the whole unit for you but i don't understand why they don't.if you have warranty it's unacceptable.anyway i found a rubber that had fallen inside and was preventing the belt to fasten.i removed it ,glue it back and all was ok.what don't pure any grease or wd40 inside as i think it might damage the belts sensor.try to poor a little of connector cleaner(pure not with oil)and see if that helps a bit.anyway goodluck
Thanks Tris Harris thanked for this post
GDRIVER is offline Reply With Quote Quote
Old 17-12-2008   #9
I've got this problem - it's a complete pain in the arse! Always rattles when it's clipped in - to the point before when the belt unclipped from the holder, which now seems OK as it only happened once....
I've been putting off going to Fiat but I really think it may have to be a trip down there!
58 Grande Punto Sporting 1.9 MJet (series 2)
PeteyPye is offline Reply With Quote Quote
Old 17-12-2008   #10
Top Dog
Trader Rating: 1
Quote Originally Posted by PeteyPye View Post
that's what i'm thinking... oh well... going to have go back there anyway by the looks of things
Old 17-12-2008   #11
I had this problem on my passenger seat belt fastener. Took it to Fiat and it was replaced under warranty no problems and haven't had a problem since.
Ex GPS x 2 and Abarth 500 owner, now drive a racing puma.
Alex_gregory_uk is offline Reply With Quote Quote
Old 17-12-2008   #12
Top Dog
Trader Rating: 1
Quote Originally Posted by Alex_gregory_uk View Post
it's going back then... cheers.
Old 17-12-2008   #13
Keep me updated! I'd like to know how long it takes to replace - hopefully this is a 10 min swap out?
Old 17-12-2008   #14
My car went in, they checked it, ordered the part, waited for the part to come in stock, went in about a week later for some other work. and the garage forgot about the seat belt fastener. I went to pick the car up and mentioned it and the part had come in, they asked if I was ok to wait an hour so I did! and it was done after an hour.
(G) rattle, rattle - noisy stilo suspension Shminkypinky Stilo 23 02-09-2013 09:06
(G) Seatbelt Reel Stickman Cinquecento / Seicento 15 08-03-2012 23:32
(S) Cigarette holder to sat nav holder daztap Bravo / Brava 21 15-04-2008 09:37
(G) seatbelt anchors John53151 X1/9 1 17-09-2007 10:22
(T) seatbelt locked kev1 Stilo 3 27-07-2007 21:38
