Hi all.
Does anyone know where i can get some of these clips from. The dealer only sells them as part of the panel (or so they claim) which are around £50 each. Perhaps i should explain - when i had the rear side windows replaced the fitter had to remove both rear side trim panels and ever since then whenever i go over speed humps or uneven ground they move about and make a lot of noise. I have had a look and it is because the clips holding the panels are now loose or broken but i cant get them on their own. I have tried other clips but they don't hold the panels tightly enough. Any ideas?
