Thread Tools
Old 18-02-2008   #1
Fanatic
Jim-Armao's Avatar
Jim-Armao has donated!
Greece
Frozen diesel
You may have seen on the news that Greece is hit by arctic cold...
My 1.9 did not like this.
I woke up today with -5 temp and the engine would not start at all.
Half an hour ago, now with +1, the engine starts but I hear a low whining noise coming from the tank area and the engine dies in about 30 seconds.
I hope that after a bit more thawing everything would be ok.
Or the cold did its damage and the fuel pump has had it.
The strange thing is that the local fiat garage advised me to add 2-3 lt of petrol in each fill-up to prevent this from happening again.
So, keeping fingers crossed and waiting... for now.
Jim-Armao is offline Reply With Quote Quote
Old 18-02-2008   #2
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Re: Frozen diesel
Quote Originally Posted by Jim-Armao View Post
Maybe its the fuel in Greece... it has been -8 here in Midlands UK over the weekend and my 1.9 GPS was no trouble at all...
Ex Suzuki SV1000S jockey, now a former 1.9 MJet Grande Punto Sporting pilot curently driving a Hyundai i30 1.6 Premium.
Ffoxy is offline Reply With Quote Quote
Old 18-02-2008   #3
Fanatic
Jim-Armao's Avatar
Greece
Re: Frozen diesel
Quote Originally Posted by Ffoxy View Post
It is common knowledge here that the fuel is crap...
Old 18-02-2008   #4
Re: Frozen diesel
In the UK we expect to have cold winters so the fuel manufacturers tweek the fuel here in anticipation.
In Greece its unusually cold...hence why they are talking about adding unleaded to drop the freezing point...this is an old trick, not required in UK any more as B.P Shell etc do it for us
blebo is offline Reply With Quote Quote
Old 18-02-2008   #5
Fanatic
Jim-Armao's Avatar
Greece
Re: Frozen diesel
Update:
A little while ago, now at +3 temp...
It started but I got the whining noise from the tank pump again.
But, I played a bit with the gas, and it did not die on me. 30 seconds later the whining stopped but I got a check engine...
I left it running a bit, restarted it and now all is ok.
From now on, when below zero temps are predicted, I will use diesel antifreeze and hope for the best.....
Old 18-02-2008   #6
Telford's Own...
Ffoxy's Avatar
Ffoxy has donated!
Re: Frozen diesel
Update:
Sounds like a plan!
Old 18-02-2008   #7
Jap Slut
puntokris's Avatar
puntokris has donated!
Re: Frozen diesel
Sounds like it's definitely fuel quality, that sort of weather wasn't anticipated in greece I imagine.
-7 when I left for work at 7:00am and no problems with mine.
C:\Users\User\Pictures\Type-r
puntokris is offline Reply With Quote Quote
Old 18-02-2008   #8
Trader Rating: 10
dave has donated!
Re: Frozen diesel
its better to add diesel antifreeze than petrol. i think adding petrol does bad things to seals in modern cars
Old 18-02-2008   #9
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Re: Frozen diesel
Dont try what the truck drivers used to do and build a SMALL fire under the tank at night...
GP tanks are plastic BTW
can you get small tubular heaters in Greece perhaps one of those under the car at night might help
Old 18-02-2008   #10
Fanatic
Jim-Armao's Avatar
Greece
Re: Frozen diesel
From talks I had at petrol stations I was under the impression that we are ok for at least -10 temp. Apparently this is not the case. So, next time, diesel antifreeze....
This cold is not that common here anyway.
Old 19-02-2008   #11
JimbbobW1977 has donated!
Re: Frozen diesel
Ive noticed my fuel pump is whining quite a bit as well recently?? I wonder if it is the cold it was -4 last on the way home, and my pump was humming away to its self.
JimbbobW1977 is offline Reply With Quote Quote
Old 19-02-2008   #12
Re: Frozen diesel
Had some trouble starting mine the other day, about -4 turned over for about 5secs, started then i had to give it some juice cos it was spluttering, big load of black exhaust smoke lol
furs307c is offline Reply With Quote Quote
Old 19-02-2008   #13
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
Re: Frozen diesel
lol dirty diesels. Mine fires up on the first crank -8*c yesterday
ChrisUK is offline Reply With Quote Quote
Old 27-02-2008   #14
Re: Frozen diesel
I have had no problems whatsoever starting my 1.9 JTD at -4C.
Don't you have Shell Optimax, BP Ultimate or Total Excellium in Greece?
georgios1976 is offline Reply With Quote Quote
Old 27-02-2008   #15
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: Frozen diesel
Quote Originally Posted by Andy Monty View Post
Think they have to be by law....maybe someone can confirm this?
Thread Tools
(T) 02 Diesel Punto -Diesel Leak Tipowski Punto (Mk2/2b) 0 05-02-2008 00:47
(G) Diesel Panda with Isofix seat or Aircon? shortie Panda 3 27-01-2008 16:41
(G) Multijets, poor fuel or should I just but petrol? PekingPanda Panda 9 01-03-2007 22:33
Ultimate diesel dan-the-man Leisure Lounge 12 02-08-2006 10:00
(T) Uno 1.7 Diesel Front Engine Mount cyberbot Uno 0 14-08-2005 11:54
