Prince7774
- Joined
- Dec 9, 2018
- Messages
- 17
- Points
- 5
Hello All,
Greetings!!
I need help regarding my Punto 2009 Model engine starting issue.
1st Problem: From past 2 years there is a starting problem, when I crank the engine for first time it wont start and on second crank with slight acceleration it will start but if I don't do slight acceleration again it will turn off. But, after starting it will run very well with out any issue.
2nd Problem: After travelling some kilometers if I stop the vehicle and try to start again it wont start immediately. It will start after 5 min. Initially, I thought it was starter motor problem but surprisingly it is not the problem creator.
Here the main story of engine not starting:
My parking lights are not working so I took the vehicle to FIAT Authorized service station. They changed the parking lights they are working fine. Suddenly, the engine didn't start and even my horn is not working. Following are all the tests performed but not use (see the attached please).
Now, FIAT service people contacted company and they recommended wet compression test. Where are dry compression test is successful and my injectors are also good.
FIAT company people are saying we may need to remove the head and see if there is any fault in the valves. By any chance whether they are worn out (my car ODO is 1,15,000KMS) Diesel engine manual vehicle. It has been almost 4 weeks they couldn't able to figure out the solution.
I request you all to kindly provide your insights and save my beauty!!.
Thanks.
Greetings!!
Thanks.
