Old 26-06-2007   #31
Re: New noise
Quote Originally Posted by T14086 View Post
Do kangaroos pee on cars like cats do here?
Bet they leave bigger paw prints on the bonnet
AllSaintChris is offline Reply With Quote Quote
Old 26-06-2007   #32
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: New noise
Quote Originally Posted by AllSaintChris View Post
LOL ..
Old 27-06-2007   #33
SNAP!
luvduvs's Avatar
luvduvs has donated!
Australia
Re: New noise
Where abouts in Aus are you? If you live in a dusty part then the noise is simply dust on the pads/dics and it will always be there. As the GP is so quiet maybe you;ve just notived it more on this car rather than any other as other noise would usually drown it out.
Failing that, turn the radio up and then you can't hear any noises to worry about
In Sydney, quite close to the beaches on the east coast and even closer to a train track (which can get dusty), but when unused its always inside the garage, so dust shouldn't be a factor.
Yeh I only noticed it because I had the audio off for once..
luvduvs is offline Reply With Quote Quote
Old 27-06-2007   #34
Sporting 1.6 Newbie
Aresby's Avatar
Aresby has donated!
Re: New noise
Another cause of brake noise is trapped gravel/stones between the pads and the disks - now that is something you should sort out otherwise you will have scored disks which will need replacing.
Easy enough to do: remove the wheel, use a small crowbar/ very sturdy screwdriver to push the brake pad into the fully retracted state (ie maximum gap between it and the disk) and firmly brush out the pad/disk area. You might have to remove the pad if the stones are now embedded into the pad. Also, watch out that the brake fluid doesn't overflow from the reservoir because it is corrosive and will knacker your paint work.
Then just pump the brake pedal to get the brake piston to push the pad back against the brake disk. It's quicker to do than to explain it, really!
Ah yes, this brings back the memories!
Was: Grande Punto 1.3 90 New Orleans Blue -- No mods -- No tweaks -- No remaps
Now: Grande Punto 1.6 120 Mjet White -- No Mods -- No tweaks -- No remaps
www.webcloudsoftware.com
Aresby is offline Reply With Quote Quote
Old 28-06-2007   #35
SNAP!
luvduvs's Avatar
Australia
Re: New noise
Quote Originally Posted by Aresby View Post
Think I'll leave it for the garage - next thing I know I'll be starting another epic on how I screwed up the car
But thanks for the advice regardless - I'll pass it on to the next garage I visit
Old 28-06-2007   #36
Sporting 1.6 Newbie
Aresby's Avatar
Aresby has donated!
Re: New noise
Quote Originally Posted by luvduvs View Post
...next thing I know I'll be starting another epic on how I screwed up the car
Careful, you will be getting T in a tiz-woz again
Old 28-06-2007   #37
Re: New noise
Do you think its anything to do with the garage it lives in? cos the `first to second gear` problem came after spending a few days in there.
oilrag is offline Reply With Quote Quote
Old 28-06-2007   #38
Re: New noise
Quote Originally Posted by oilrag View Post
Unless the garage i used to take my old car to has mysteriously upped sticks and shipped itself to Kev's back garden then i'm sure thats not the problem.
If it is the same garage I sympathise as everytime i took my car to that garage it came out more broke than it went in
Wonder how it got there
Old 28-06-2007   #39
Re: New noise
Outer limits, I was thinking
Old 29-06-2007   #40
SNAP!
luvduvs's Avatar
Australia
Re: New noise
Interesting theory - why would it make a difference?
Btw I've noticed another new noise () - this time when I drive off in the garage - makes a low humming noise when I turn left. I can only hear it when I drive off, and no other time.
Linked perhaps?
Old 29-06-2007   #41
Re: New noise
Linked perhaps?
Power steering pump.
Old 29-06-2007   #42
SNAP!
luvduvs's Avatar
Australia
Re: New noise
If that's the case shouldn't it hum all the time instead of just during the initial drive off?
I just tried it at my parent's place and no humming. So maybe that garage theory isn't silly afterall - maybe its cursed?
Old 29-06-2007   #43
Shauncorwyn has donated!
Re: New noise
The steering rack is electrically powered not hydraulic.
Shauncorwyn is offline Reply With Quote Quote
Old 29-06-2007   #44
Forum Moderator
T14086's Avatar
T14086 has donated!
Re: New noise
Get garage exorsiced
Old 29-06-2007   #45
Re: New noise
maybe its cursed?
Its not called `Christine` is it Kev?
(G) graunching noise when pulling off. Pls help? manc lad Punto (Mk2/2b) 4 24-05-2007 18:59
(G) noise in neutral, 1st & 2nd gear commiepanda Panda (Classic) 5 27-04-2006 00:07
(T) Noise from the engine. TheCROW Bravo / Brava 3 06-04-2006 07:17
(T) continuous clicking noise wiper motor? HELP nickphonics18 Punto (Mk2/2b) 2 13-02-2005 14:14
(T) Rear noise when moving off Paddy_Punto Punto (Mk2/2b) 2 25-12-2003 17:42
