Sounds serious.. I think you'll need both a new window and a new door :chin:
Yep oil is fine.
Nevermind - its ok when others ask a stupid question but its not ok when I
do.
By the way, did you ever get that autobox sorted?
i can't here this brake noise, does that mean i have no brakes?![]()
Anyway, I think we owe it to Kev to make this another epic
I have also noticed that slight grinding noise in other cars (not the GP but then again the diesel noise more than makes up for that) especially when you have new brake pads fitted as there is a course layer on new pads to 'clean up' the disk. That's why the technicians always tell you take it easy for the first 100 miles of city driving with new pads.
But I've done 5000kms by now (only drove it two/three times a week for the last 8 months), so the brake pads can't be considered new anymore, right?
As you've all figured out I don't know too much about cars and I really hate to turn this into another epic, so can someone shut me up by clarifying if I understand the below correctly?
- Grinding noise comes from (new) brake pads/discs rubbing against each other, even though I'm not stepping on the brakes.
- Would be less noticeable when they become worn.
- Its normal and most cars make that noise too.
Do kangaroos pee on cars like cats do here?
Where abouts in Aus are you? If you live in a dusty part then the noise is simply dust on the pads/dics and it will always be there. As the GP is so quiet maybe you;ve just notived it more on this car rather than any other as other noise would usually drown it out.![]()
Failing that, turn the radio up and then you can't hear any noises to worry about![]()
Another cause of brake noise is trapped gravel/stones between the pads and the disks - now that is something you should sort out otherwise you will have scored disks which will need replacing.
Easy enough to do: remove the wheel, use a small crowbar/ very sturdy screwdriver to push the brake pad into the fully retracted state (ie maximum gap between it and the disk) and firmly brush out the pad/disk area. You might have to remove the pad if the stones are now embedded into the pad. Also, watch out that the brake fluid doesn't overflow from the reservoir because it is corrosive and will knacker your paint work.
Then just pump the brake pedal to get the brake piston to push the pad back against the brake disk. It's quicker to do than to explain it, really!
Ah yes, this brings back the memories!
Careful, you will be getting :worship: T in a tiz-woz again...next thing I know I'll be starting another epic on how I screwed up the car
Do you think its anything to do with the garage it lives in? cos the `first to second gear` problem came after spending a few days in there.![]()
