![]() | #31 |
Posts: 8,120 Thanks: 308 Trader Rating: 3 ![]() | I have asked mario cinq for ya ![]()
__________________ Wanted : Nothing at the moment |
![]() | #32 | ||
Posts: 3,047 Thanks: 128 Trader Rating: 0 ![]() | so what are the future plans with this?
![]() | #33 | ||
Posts: 2,136 Thanks: 0 Trader Rating: 0 | i dunno ![]() ![]() maybe use it for work was just wondering since the manifold has the 2 holes instead of the one hole like the sei cheers for asking mariocinq
![]() | #34 |
Posts: 8,120 Thanks: 308 Trader Rating: 3 ![]() | Well it is best to use P75 exhaust mani they are much better. ming
![]() | #35 | ||
Posts: 2,136 Thanks: 0 Trader Rating: 0 | we shall see what happens as that means striping the engine down and then waiting on a new downpipe and then hopin it will match up with the rest of the sei exhaust ![]() but plus side timing belt has now arrived just waiting on the new clutch and thats that for the engine top end rebuild
![]() | #36 |
Posts: 8,120 Thanks: 308 Trader Rating: 3 ![]() | Well if you not wanting to use the P75 exhaust then i'll take it ![]() What are you actually doing to the engine ![]() ming
![]() | #38 | ||
Posts: 2,136 Thanks: 0 Trader Rating: 0 | what do you mean what am i doing to the engine ?? new timing belts tensioner head gasket valve seals usual thing that should be done really and then plopping it in the sei hmm dunno if i will need the mpi alternator or not but cheers for the offer will keep it in mind ![]()
![]() | #39 |
Posts: 8,120 Thanks: 308 Trader Rating: 3 ![]() | Na just use the alternator from ur sei, it'll be the same. Ming
![]() | #40 | ||
Posts: 2,136 Thanks: 0 Trader Rating: 0 | update timing belt kit and the new clutch kit is here ![]() ![]() you up for the fitting anytime soon mark ![]() ![]()
![]() | #41 |
![]() | i can get it fitted any time from tomorrow tea time onwards ![]() had a play with the exhaust last night, it's not going to be a straight forward job...... still need to do the headlamp, but its a 5 minute job, have all the connectors and the plug in the garage ![]() btw, adjusted the bmw's handbrake yesterday aswell, remind me to return that spanner to you! ![]()
__________________ www.fiat-scotland.com,the home of all things both scottish and italian. it's a bit like having an irn bru with your pizza, only much tastier ![]() 98 Fiat Cinquecento Sporting 16v, 94 Land Rover Discovery 300tdi |
![]() | #42 | ||
Posts: 2,136 Thanks: 0 Trader Rating: 0 | thats not a problem mate we shall have a look at the exhaust as my astra system was similar i just used so steel cable ties to move it slighlty over ![]() but yeah tea onwards should be ok i think ![]()
![]() | #43 |
Posts: 8,120 Thanks: 308 Trader Rating: 3 ![]() | Right, you need to use the cento loom with a P75 ECU. Then splic the injector wire to connect to the 4 injectors ![]() from mariocinq. "ming used the cinq loom with punto ecu and spliced the 4 injectors together which is what i was advised to do when i di it cos i gave up trying to figure out how to wire the punto loom in as it was all backwards lol" Ming
![]() | #44 | ||
Posts: 2,136 Thanks: 0 Trader Rating: 0 | ok well the ecu is easy enough to get hold of anyway so ill see how it goes as just a straight swap over with the SPI throttle body
![]() | #45 |
Posts: 8,120 Thanks: 308 Trader Rating: 3 ![]() | ![]() ok well the ecu is easy enough to get hold of anyway so ill see how it goes as just a straight swap over with the SPI throttle body sounds like it might be better idea sticking with using the head off the seicento and staying spi? When using the P75 ecu you will also need the code box and key. Ming
