Har Har! My insurance is £187 a year, comp, all in!
(The only advantage to being 32
Yeah - had 9.5 secs against a stopwatch to 60 and gave up at 6200 revs in 5th, seeing as though it's redlined at 6k...
Would go off the clock down hill prob'ly.
Throttle body - try the same breakers you get your engine from, might even come still attached!
Superchips, look for your local dealer on
http://www.superchips.co.uk
Spacer - make one from 10mm plate like I did (use gasket as a template)
tame welder - ring around fabrication shops in the yellow pages?
cam belt/clutch/'stat/manual - local car bits shop or Fiat
Hoist - hire one (cost me £20 for a day) but you won't need one if you're not doing it yourself
swearwords - you could always post a request for some
Labour - you're looking at about a day's work for a garage to swap an engine, so £200+ maybe?
Pete.
Cinq sporting 1242cc
http://mysite.freeserve.com/close_to_cracking_up/
