Thread Tools
Old 28-10-2018   #1
Spain
heating problem ok
my seicento had a problem with the heating, the steel cable that moved by the wheel was bent and did not fit into the sheath.
I have disassembled cover (3 screws) and then I have reached another small screw that holds the cable sleeve.
thus I have the stretched cable giving heat to return to give the straight form. A lot of oil and it seems to come back in its place
I have put a cable on the other side of the wheel, it seems to be more direct and it will be harder to bend again.
picture both arrows to see site difference
Thanks htchd7 thanked for this post
Likes htchd7 liked this post
ccavalles is offline Reply With Quote Quote
Old 29-10-2018   #2
Spain
Re: heating problem ok
tested on the road and I already have heating, I think the way to prevent breakdowns is good lubrication of the cable.
Old 05-11-2018   #3
Serbia
I have opened mine, all cables have ok movement, all in place, but heating is still on. I must have problem from the other side inside engine compartment. :/
htchd7 is offline Reply With Quote Quote
Old 05-11-2018   #4
Spain
The problem could be on the other side of the cable. you have to look for a scheme and see where it is.
Old 06-11-2018   #5
Serbia
I will see. It could be cable or heater valve.
Old 06-11-2018   #6
Spain
Mine now seems to always get hot air, so the problem is cable. Before I did not do it and when fixing it, it happens to me
Old 07-11-2018   #7
Serbia
After fixing the cable, now you have heating all the time, like me? Might be the other side of the cable under the hood. :/
I tought that heater valve is blocked-seezed on mine. But it is strange that now you have the same symptoms.
Old 07-11-2018   #8
Spain
Quote Originally Posted by htchd7 View Post
Exactly, now in cold position, temperate air. I think that before the cable was damaged, it was already happening (two or three years ago) I suppose if I stretched the cable by hand, it would be cold as before.
Old 07-11-2018   #9
Autotest Special
rallycinq's Avatar
Trader Rating: 1
rallycinq has donated!
The Sei is known for giving cock trouble. (this joke won't work unless very familiar with the English language)
D
Old 08-11-2018   #10
Serbia
Haahah, we have same jokes here in Serbia. It is very understandable to me, it is similar sense of humor. hahahahha
Old 09-11-2018   #11
Spain
I have disassembled and stretched the cable again and now if the cold natural air comes out. It is problem of cable entry and exit butt.
Old 09-11-2018   #12
Serbia
I hope that you put some oil inside cable tube, to lubricate. I will try to do the same. I am going on weekend roadtrip.
Old 09-11-2018   #13
Spain
Yes, I put silicone in spray. It is not a car for daily use, so it is not much inconvenience either.
good trip
Thread Tools
(T) Heating Problem stoker Cinquecento / Seicento 17 31-08-2013 09:04
(T) Heating Problem fiatinjeti Palio 3 23-01-2012 09:41
(T) Over Heating Problem Johnrileys Stilo 1 02-05-2011 16:25
(T) Yet another over heating problem... adaze Punto (Mk2/2b) 2 19-03-2008 19:35
(G) heating problem???????? HELP jamie03 Punto (Mk2/2b) 1 30-12-2006 20:54
