- May 1, 2014
- 273
- 170
Hello,
I'm a bit lost here...
I've done several job on my car: timing belt, water pump, auxiliary belts, cooling system flush and coolant change (g12+ conversion), etc.
All seemed good at the time, except for a faint noise (like worn ball bearing) at a certain RPM.
After few weeks, my engine starts to cut-off the power every time I reach a specific rpm (3600rpm).
After that the same problem appears when I reach 2500 rpm (yellow engine light turns on just for the time needed for a drop in rpm, then the light turn off).
No error shows up on ecuscan.....
Any suggestion? faulty water pump? excessive timing belt tension (I've use the rule of the thumb that I've found on the forum to tensioning it)?
Thanks for hearing me out....
