im Axle Specialists
Thread Tools
Old 13-12-2011   #1
engine won't start won't bump start engine seized ?
HI can anyone help? I think my engine is dead!
seicento 2001. sx 1.1 58 k miles . Been driving great but been losing water.I thought head gasket as a bit smokey but no mayonase inside filler cap. been topping up water and waiting for christmas hols to fix.suspected water pump.
reversed into parking space last night and noticed more smoke than normal . When I returned to car it would not start. Head lights dim when I try but it does not feel like starter motor. It feels like engine won't turn over cos starter not able to turn it. I got some mates to push. 3 adults found it really hard to push and as soon as I let out clutch in 2 nd they could not push it. I think it's seized .I left it in school car park last night and am arranging a friend to tow home. Is there anything else it could possibly be ? I'm reasonably handy but spent most of my life on air cooled vw's .
seanhyde is offline Reply With Quote Quote
Old 13-12-2011   #2
Trader Rating: 5
fingers99 has donated!
Re: engine won't start won't bump start engine seized ?
Seized or possibly gone hydraulic. Remove all plugs and see if it'll turn over.
M12 fund 20
fingers99 is offline Reply With Quote Quote
Old 13-12-2011   #3
Inline for a good time!
chrisb7777's Avatar
chrisb7777 has donated!
Could be hydrolocked? Take out the spark plugs and see if it turns over, if not then it probably is seized. Bad water pump wouldnt cause it to loose water unless it is leaking. Could be headgasket still as you wont always see the mayo on dipstick or filler cap. Was there steam/smoke coming out of the exhaust or engine bay?
Hope this helps
Chris
chrisb7777 is offline Reply With Quote Quote
Old 13-12-2011   #4
Quote Originally Posted by fingers99 View Post
Thanks for quick reply. what does gone hydraulic mean ?
Old 13-12-2011   #5
Quote Originally Posted by chrisb7777 View Post
Hope this helps
Chris
smoke was coming out of exhaust
Old 13-12-2011   #6
Trader Rating: 5
Basically a cylinder fills with water (or any liquid). Liquids cannot be compressed, so the engine can't turn over.
M12 fund 20
Old 13-12-2011   #7
chrisb7777's Avatar
Quote Originally Posted by seanhyde View Post
If its smoke then is oil, or overfuelling. Steam its water. It does point to the headgasket however. If it turns out your cylinder is full of water then this is almost definealtly a head gasket unless you have a cracked block or head
Old 13-12-2011   #8
thanks loads. I will do checks when I get it home. Be gutted if engine is gone as only got car 8 months ago for daughter to learn in. One owner full service history less that 50 on clock. I love it use it all the time and leave my vw transporter on the drive. Head gasket looks do able ,if whole engine dead then looks like Ill try and get a used one of ebay
Old 13-12-2011   #9
chrisb7777's Avatar
I doubt that the engine would be seized so fingers crossed for that, aslong as you were keeping water and oil in it have you noticed any rough running on a cold start?
Old 13-12-2011   #10
arc
this is where i stand
arc has donated!
Take the spark plugs out and turn it over again. If it was hydrolocked then you'll get water fired out of the plug holes.
If not, check the alternator hasn't seized.
.:: 1368cc 16v Cinquecento ::.
arc is offline Reply With Quote Quote
Old 13-12-2011   #11
chrisb7777's Avatar
Quote Originally Posted by arc View Post
Surely a seized alternator wouldnt cause an engine not to turn over like that?
Old 13-12-2011   #12
Trader Rating: 5
Completely seized they can, if they don't break the belt first. Good shout by Arc.
M12 fund 20
Old 13-12-2011   #13
Trader Rating: 3
ycming has donated!
Remove alternator belt and try starting!
ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 13-12-2011   #14
Once again thanks to all of you .I will let you know what it is when I find out
Old 13-12-2011   #15
Hi
Another option is the clutch thrust bearing can jam itselt in the clutch tines.
Noel
standard Sei Sporting except for
colour matched ice scraper, screw driver,
& steering wheel lock i.e yellow car
spare alternator belt, clutch cable & bulb set, 2x overalls
Pep0 is offline Reply With Quote Quote
Thread Tools
new mamber help engine won't turn overor bump start seanhyde Newbie Central 2 13-12-2011 16:16
(T) Engine won't start jayovnbh Punto (Mk2/2b) 17 20-01-2011 15:50
(T) Help Please -Engine won't start IanC123 Multipla 18 14-04-2009 16:52
(T) Engine won't start Lozzy08 Punto (Mk1) 25 16-11-2008 20:29
(T) Engine won't start Alan Birch Cinquecento / Seicento 2 27-06-2003 21:03
