Morning,
Our Sporting does overheat, having had a look and poke around I have observed the following;
The fan does not work - blown fuse
I replaced the fuse and the fan spins but then blows the fuse straight away.
Bypassed the fan switch with a piece of copper wire, and the fan starts but then the fuse blows again.
Disconnect the fan and replace the fuse, obviously the fan does not work, but the fuse does not blow either.
Is this suggesting that the fan motor is the problem ?
Other than a Fiat bit is there a cheaper alternative to this ?
Del
Del
